Need a little help tweaking my bios on a NF7-S
Renob
7,596
Ok here is the hardware.
NFS-S
Mobil 2600
512mb Corsair XMS cas 2 mem
ATI 9800 pro
Enermax 550wat
Im running it at 12x200 at 1.52 volts and here are my bois settings, please let me know If I should change anything.
12x200
cpu FSB/dram ratio 5/5
cp cor voltage 1.52
ddr sdram voltage 2.8
chip set voltage 1.7
agp voltage 1.5
agp aperture 64m
agp fastwrite enabled
Mem timings Turbo 7 2 2 2
bootoo
671
I don't have that motherboard; only thing I would do is set fastwrites to disabled (works better for me) and set agp aperture size to 128.
I admire your memory timings! Nice job all around.
loafbred
836
58
Memory timings work a little better at 2-2-2-11 with 6/6 bus/dram ratio on nForce2's.
Chipset should be stable at 200 bus with 2.6v instead of 2.7, which will reduce heat.
Run a cpu benchmark like CPU Mark99 to see if the multiplier you're using is a problem. Some will cause performance drops. Try at multis 11 and 12.
PliotronX
8,883
107
Is enhanced CPU interface enabled? That one gave a good boost on my board, and also try playing around with the tRAS a.k.a. row active delay (it's the 7 in your timings). A lot of folks have found a setting of 11 gives a small gain. You can make testing easy by using the Nvidia System Utility and changing it from within Windows. I would also play with disabling FW and making sure SBA is enabled in Windows as that seems to make my 9700p happy (~+1 FPS w/FW off, another ~+1 FPS w/SBA on). You can change these on the fly using various utils such as the low level hardware page in RivaTuner, Powerstrip, WPCREDIT, etc.. I agree with Bootoo on the AGP aperture too, my Radeon likes 128 :) Happy tweakin' :beer:
Shimmishim
7,504
it likes 128 because radeon pros have 128 or 256 megs of ram...
so if you have one with 256, make sure to set the apeture to 256 rather than 128 :)
