- Mar 26, 2005
- 4,094
- 123
- 106
Right now I have:
CPU Volt Control: at stock
Mem multiplier: 2.0
CPU Host Frequency: 400MHz
With this I have 2.8GHz(in sig). As I understand my main limitation is the memory that is 400MHz and the possible high temps. I couldn't get better memory or a good cooler in the past because I couldn't afford them, but now I got a little cash saved up, and I can try to go a little higher.
How do you think I should do this? Is better RAM a must, or I can push my current ram a little higher? Do I need a cooler just for the CPU or for the NB chip as well?
Can you please recommend some good CPU and NB coolers? I need something that is fairly easy to install and something that will work right out of the box. I know there are some coolers that require a user to purchase a fan separately - I don't need that. I need something that is ready to install and use.
Mem multiplier: 2.0
