need a little help installing bluetooth keyboard
Pierce
hi this is my issue
I have a Samsung galaxy tablet and paired it with a SILVER gtmax full size bluetooth keyboard. It came with no manual and for some reason it wont connect... the light on the keyboard keeps blinking. There is a connect button and pressed it for 30 seconds and got nothing
please any other suggestions? Really need this to work, thank you
Bluetooth devices usually need to be put in pairing mode before device will be seen or connect/pair, try pressing and holding the connect button till the light either stays solid or blinks blue and red. Then try pairing.
its blinks blue, so youre suggesting i hold it for a little longer?
i will go ahead and try that, thanks.
