- Jun 24, 2002
- 6,098
- 0
- 76
I just got my new system together:
AMD Athlon 64 3200+ (Winchester) @ 2.6GHZ
Asus A8N-SLI Deluxe Motherboard
1GB PDP PC3200 w/XBL
BFG 6800GT OC PCIe Video Card
WD 74GB Raptor
Zalman CNPS7000B-Cu
CoolerMaster Centurion 5 Mid-Tower Case
Enermax NoiseTaker 600W PSU
Samsung 193P LCD
My overclocking has been pretty sucessful, especially considering what a PITA this board is to overclock. Anyway, with my current OC, I need 1.575V going to the chip, which I am fine with, but my current HSF can't seem to keep the thing under 55C load. Even though this isn't a bad temp, I would really like to get it under 50C at a reasonable noise level, so I thought I would look into water cooling. I have run a Koolance system before on a previous machine and it worked pretty well at keeping my AXP 2500+ @ 2V relatively cool. The problem is that I know there are better performing options out there. I would like to try and spend under $450.00 total, as I can get the following Koolance system for about $413.00 Shipped:
Koolance Exos Al External Water Cooling System
CPU-300-H06 CPU Waterblock
GPU-180-V06 Motherboard Chipset Waterblock
VID-NV1-L06 Geforce 6800 Series Waterblock
AMD A64 Adapter
Koolant Refill
What are some other options, what would you recommend to a semi-newbie going into a DIY watercooling setup? Any help, suggestions, or recommendations would be greatly appreciated.
Thanks!
BTW, I would also like something that will allow me to expand to add another Video Card waterblock when I can find another PCIe BFG 6800GT OC in stock!
WD 74GB Raptor
Zalman CNPS7000B-Cu
Samsung 193P LCD
AMD A64 Adapter
Koolant Refill
Thanks!
