Im kinda new to the pc gaming hardware stuff i have a hp slimline 5120y pc it has onboard nvidia 6150 graphics but its not enough for starcraft 2 and cant seem to find a graphic card to fit my pc can anyone tell me where i could find one and what to look for
You need a low profile card. Probably not a high end one as it doesn't look like you have much room, but you should open up the case and see how long of a card you can fit in there.
Your power supply could also be an issue for "high end" low profile cards, since the 7750 processor is not too efficient.
I would look into a 5570, I know they come low profile and they out perform the 4650 while consuming less power. They are a litlte more expensive, but worth it over a 4650 in my opinion.
