Need a GPU for Lightroom 5.7 photo editing on a 27 incher monitor and 4 year old rig
philmar
24
Impulsively I went online all of last night and in to the early morning and in a sleepy mindset I pulled the trigger on a BenQ SW2700PT. http://www.benq.ca/product/monitor/sw2700pt/
When I awoke this morning I realized that I'd neglected to consider whether my PC can handle it. My expertise in pixels, not bits and bytes.
I don't have a graphics card - I use the onboard Intel® Z77 chipset graphics: Intel HD 4000 on my Ivy Bridge i7 3770K
My mobo is the ASUS P8Z77-V PREMIUM (external link).
https://www.asus.com/ca-en/Motherboards/P8Z77V_PREMIUM/...
From what I've subsequently read the new monitor's increased resolution and resultant complex calculations will tax my CPU. I'm wondering (hoping) that a dedicated GPU will help.
I do NOT game or edit video. I do only light netflix viewing but the biggest demands on my system are RAW photo editing. Moving pixels around and displaying it on a high res monitor involves a lot of CPU calculations.
Will a GPU help my pc performance?
My understanding is that Lightroom 5.7 does not make use of GPU acceleration. A new LR 6.0 version does and this may force an upgrade for me.
I was hoping for a complete new rebuild in 2 or 3 years. I hope it isn't required as a result of the new monitor purchase.
Any recommendations on the best value (bang for buck) GPU that could help me (and ideally be used in my next build)?
I run W10 64 bit, 32 GB RAM, 1 SSD and 2 spin HDs and Antec 620 W PSU.
Sincerest thanks for any helpful suggestions!
cfenton
277
99
101
My understanding is that Lightroom only uses the GPU in certain tools in the Develop section. It's not going to help your export times, for example. If you don't have Lightroom 6, I don't think it uses the GPU at all.
As for GPU power, I think it's a case where having a GPU is helpful, but beyond that having a powerful GPU doesn't make much difference. Even the HD4000 might be enough to use the GPU acceleration features. Certainly the HD4000 is fine to drive that monitor in general.
philmar
24
I realize the following site is a commercial site devoted to selling you hardware but their advice is interesting.
https://www.pugetsystems.com/recomm...-Adobe-Lightroom-141/Hardware-Recommendations
Video Card (GPU)
In Lightroom CC 2015 and Lightroom 6, the software is able to utilize the power of your GPU to improve performance when editing images in the Develop module. At the moment, the performance gains are fairly modest, although Adobe has been investing heavily in GPU acceleration. While a high-end GPU is not required to get the benefits of GPU acceleration in Lightroom, it may be a good idea to get a slightly faster GPU than you think you need to help future proof your system.
Lightroom is also very light on VRAM requirements, so even a card with just 2GB of VRAM should be more than enough. However, if you work with large images in Photoshop or use a 4K monitor it is a good idea to use a card that has at least 4GB of VRAM if possible. Workstation video cards are not required for Lightroom, although if you will be using a 30-bit monitor you will need a NVIDIA Quadro video card as GeForce cards currently do not support 30-bit display output.
Although it is likely that Adobe will increase GPU acceleration support in Lightroom in the future, the current demand on the video card is actually relatively light. We recommend either a GeForce GTX 1060 GeForce GTX 1070.
Is my BenQ SW2700PT a 14 bit monitor?
CuriousMike
3,044
544
I agree with what you found above; GPU acceleration is modest at best for Lightroom.
philmar
24
Received the monitor today and setting up was a breeze. Base, arm and screen easy to assemble.
Had absolutely NO problems running it on my 4 year old processor's HD4000 graphics - even have the NEC 20WMGX2 as a 2nd monitor with both running at their native resolutions.
The BenQ is at 2560x1440 - w10 drivers were installed but not as easily as the manual said it would be.
Good news: It is connected using the supplied mini DP to DP wire: the Mini DP plug in my Intel mobo's Thunderbird port and the DP plug in to the monitor. Never thought that I'd ever use that port but am so glad I didn't have to go out and waste an hour buying another cable. Still don't know why they included it and not a DP to DP cable.
I am happy to say that I see almost NO performance degradation with LR 5.7.
Small difference: when in Library mode and scrolling in Grid view is a bit choppy.
Small difference: Bit more time required to cycle between regular and zoom when in Loupe view.
Performance differences are negligible - to the point I regret the considerable time I wasted researching it. Guess my i7 3770K and mobo were good choices 3 years ago...and happy I won't need a GPU!!
Though it is early days thus far...I'll report any issues.
XLer8
37
9
Yeah excellent collection. Thanks for link. The Scottish fest really stands out!
I dont want to start a new topic so I hope Im not breaking any rules...
Can a older GPU run and edit a photo forum database with cuda? I know its overKILL though.
philmar
24
Did a system upgrade. Monitor is playing very well with LR now. At time of first use, it was slowing down when I was using crop tool - this forces LR to change zoom to fit in to screen. As a result, I added a second SSD as the LR lrdata previews file (> 100 GBs) had almost filled my SSD C boot drive. Also I swapped out a spin hard drive that was dying with a new one. The problems disappeared completely.
I'm not a techie, but I suspect it had to do with the windows page file being on the 'soon to be toast' data dick drive as well as the fact performance was degraded by my boot drive being near capacity. I've moved the LR catalogue and all the lrdata/lrcat files on to a new secondary SSD drive.
One or both of the actions above has resulted in a performance boost. My i7 3770K and intel onboard 4000 graphics are now running LR on the BenQ with NO appreciable perceptible difference when compared to the smaller 20 inch monitor I used previously - and have hooked up as a second monitor. Also I calibrated the BenQ with the BenQ software which adds the profile to the monitor's LUT (just reporting what I read - can't say I understand what that means). Someone suggested that this could also take some of the burden off of the CPU.
The only difference I see now is when I scroll quickly between files in the Library mode. They take longer to come in to sharp focus that they did previously.
I did all these changes at the same time so i can't say with any certainty which of the 3 things contributed most to my performance boost.
philmar
24
I'm wondering if even a cheap vid card would help a bit - anything $100 or less.
Also do I lose something by using the mini-display cord plugged in to the thunderbolt port? Could a a cheap GPU take some of the load off of the CPU?
Would anything be gained if I had a cheap GPU with a display-port port that I could use a display-port to display-port cord with?
CuriousMike
3,044
544
For LR5.7, a new GPU isn't going to make much of a difference.
As I mentioned above, even if you upgrade to 6.0 (which Adobe isn't going to have stand-alone LR after 6), the performance upgrade would be modest.
LR just sucks as far as speed is concerned. You should follow Adobe's recommendations for helping speed it up (why the hell do they have a dedicated page to help speed up their program; shouldn't it come out of the box sped up?) - You can also google other peoples suggestions for speeding it up.
None of it helps. (You have a good CPU and SSD's - I presume you either cache or have your previews stored on the SSD).
The only thing that LR definitely responds to is clock speed.
If you haven't overclocked your 3770k, do so as much as possible.
If you have the stock heatsink fan, you'll be FAR better off spending $35 for an aftermarket heatsink then spending money on a GPU.
philmar
24
NB > Local pc store having a sale...I've decided to buy a Radeon RX 460
Already have a CPU Cooler Master Hyper 212 EVO...will oc the cpu soon.
greatnoob
968
395
An overclock should help out a lot. You also have 32gb of RAM, create a 4gb RamDisk (I use IMDisk), set temp directory to said drive. Check how much dynamic vram is allocated to the HD 4000 and if it's less than 1.7gb go into your BIOS and increase it - keep in mind that this only helps if Lightroom actually makes use of hardware acceleration. Lastly, if all 4 sticks of RAM are the same and if they can be overclocked (check if they have XMP profiles in BIOS) then it's a good idea to clock them higher since memory bandwidth very well might be a bottleneck for your use case.
Solid albums by the way!
