Lean usually means a vacuum leak(gasket/vacuum line) and/or bad o2 sensor. Those are the 2 biggest causes. Since you did not say there are any other codes then the fuel injectors are probable ok. I have seen a lean conditioon when 1 F/I was bad but it also had a misfire for that Cyl as well.
Not sure where you live since you don;t have your profile filled out but if its near N.VA (DC) then you can come by and I can put my scanner on it.
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
So looks like it may be a bad O2 sensor on bank1 or air leak on that bank.
