need a cut and paste job done.
P1553D
44
i would greatly appreciate if someone would go over to gamefaqs.com. and cut/paste the fatality list for mk decption on the xbox. i am at work and gamefaqs.com is blocked for me. thanks in advance.
jammur21
1,629
Fatalities
After you have beaten an opponent and the announcer yells "Finish Him!" it is time to input a Fatality. Fatlities require a set distance to perform. The distances are:
Close: 1 step away from your dazed opponent
Sweep: 2 steps away from your dazed opponent
Far: 5-6 steps away from your dazed opponent (end of arena)
After you are at the required distance press the L trigger to enter the Fatality stance. Then input the fatality code.
Code Effect
Down, Down, Up, Up, Y (close) Ashrah's First Fatality
Forward, Down, Forward, Down, Y (sweep) Ashrah's Second Fatality
Forward, Up, Down, Y (close) Baraka's First Fatality
Forward, Down, Back, Forward, Y (sweep) Baraka's Second Fatality
Down, Up, Forward, Forward, Y (sweep) Bo Rai Cho's First Fatality
Up, Back, Forward, A (sweep) Bo Rai Cho's Second Fatality
Down, Up, Back, Back, X (sweep) Dairou's First Fatality
Down, Down, Back, A (close) Dairou's Second Fatality
Up, Down, Back, Forward, A (sweep) Darrius's First Fatality
Down, Forward, Forward, Up, X (close) Darrius's Second Fatality
Down, Back, Back, Down, A (sweep) Ermac's First Fatality
Back, Down, Back, Down, B (sweep) Ermac's Second Fatality
Down, Forward, Forward, Up, B (close) Havik's First Fatality
Forward, Forward, Forward, Back, Y (sweep) Havik's Second Fatality
Forward, Up, Back, Down, X (sweep) Hotaru's First Fatality
Down, Forward, Back, Forward, Y (close) Hotaru's Second Fatality
Back, Forward, Up, Forward, X (sweep) Jade's First Fatality
Back, Forward, Forward, Forward, Y (close) Jade's Second Fatality
Forward, Up, Up, Up, A (close) Kabal's First Fatality
Up, Up, Down, Down, Y (close) Kabal's Second Fatality
Forward, Forward, Back, Back, Y (sweep) Kenshi's First Fatality
Up, Forward, Back, Forward, Y (sweep) Kenshi's Second Fatality
Back, Forward, Forward, Back, B (far) Kira's First Fatality
Up, Forward, Down, Back, A (sweep) Kira's Second Fatality
Down, Back, Forward, Down, B (close) Kobra's First Fatality
Forward, Back, Forward, Forward, Y (close) Kobra's Second Fatality
Forward, Forward, Forward, Forward, X (sweep) Li Mei's First Ftality
Up, Back, Forward, Forward, B (sweep) Li Mei's Second Fatality
Back, Back, Back, Forward, Y (sweep) Liu Kang's First Fatality
Forward, Forward, Up, Up, A (sweep) Liu Kang's Second Fatality
Forward, Forward, Down, Down, X (sweep) Mileena's First Fatality
Up, Up, Forward, Forward, A (far) Mileena's Second Fatality
Back, Forward, Back, Forward, X (far) Nightwolf's First Fatality
Down, Forward, Down, Up, Y (sweep) Nightwolf's Second Fatality
Back, Forward, Back, Forward, B (must be noob) (sweep) Noob Saibot & Smoke's First Fatality
Up, Down, Down, Forward, Y (must be smoke) (sweep) Noob Saibot & Smoke's Second Fatality
Back, Down, Forward, Down, X (sweep) Raiden's First Fatality
Up, Down, Forward, Forward, X (far) Raiden's Second Fatality
Forward, Down, Forward, Forward, X (sweep) Scorpion's First Fatality
Forward, Back, Forward, Back, X (close) Scorpion's Second Fatality
Up, Down, Down, Forward, A (close) Shujinko's First Fatality
Back, Up, Forward, Forward, X (close) Shujinko's Second Fatality
Back, Forward, Forward, Back, X (sweep) Sindel's First Fatality
Up, Up, Back, Forward, A (sweep) Sindel's Second Fatality
Forward, Back,. Down, Forward, Y (close) Sub-Zero's First Fatality
Back, Down, Forward, Down, X (sweep) Sub-Zero's Second Fatality
Forward, Down, Down, Down, X (close) Tanya's First Fatality
Up, Back, Forward, Up, A (close) Tanya's Second Fatality
