Need a complete hard drive delete.
Theguynextdoor
I have a good HD already and the one I want to format is already hooked up. Is there a program that runs in windows that can COMPLETELY format the HD. I already used windows to do it, but I want something to comfort my paranonia a little more.
Use DBAN. Standard US Department Of Defense method ought to ease your mind a bit, but it can go further than that if you've got the time 🙂 Expect the seven-pass DOD method to take... quite a while. I would launch it before going to bed. 😉 Also, don't have any other drives in the system that you don't want nuked.
Oh, and if you want something you can run in Windows, let's say the blanked drive is drive letter F:. Remove all data from F: and then use this command:
cipher /w:F:\
This overwrites all the free space on F: with three layers of encrypted junk, then deletes it all. Not positive, but I believe this would only work if the partition is using the NTFS file system. Probably not as good as DBAN, but I've tried picking up anything off of a drive using PC Inspector file-recovery software after doing a cipher run, and it wasn't coming up with anything but gibberish files.
edit: cipher doesn't take as long as DBAN, about 1 minute per GB on my 15000rpm SCSI drive. It is also safe to run on your C:\ drive, since it only does its thing on whatever space is blank.
Originally posted by: Theguynextdoor
Awesome thanks guys, I'll run cipher. Also after i run cipher can i install an OS on that HD later on?
Yep, no problem at all.
