Need a Case suggestion
Zarick
396
I need a new case. I want something that has some great cooling capabilities. I need something that comes with no powersupply since I have a trupower 430. I would like it to cost less then 100 bucks (less than 75 preferred).
Suggestions?
Trashman
2,040
I just bought a Antec PlusView1000AMG, great case, plenty of cooling.....Newegg.com.
Gotta love the drive rails and snap-in drive bays.
rudeguy
47,351
14
61
cant go wrong with antec...i love mine...is yours one with the quick release side?
phatj
1,837
Can never go wrong with an antec... you could probably get a lian-li case though... good if your are overclocking.
Trashman
2,040
Just the standard side panel, with window....don't think they refer to it as a quick release though.
ArmchairAthlete
3,763
nick1985
27,153
Originally posted by: ArmchairAthlete
These cases are awesome, I have one (or a VERY similar one):
Chieftecs with BIG clear side windows, front USB, room to install 4 case fans, comes with 2 fans, lotta bays, looks badass, etc etc.
Black:
http://www.newegg.com/app/viewproduct.asp?description=11-125-211&DEPA=1
Silver:
http://secure.newegg.com/app/CustratingReview.asp?item=11-125-212
For about $65 with no PSU like you said.
EDIT: there are even more colors, just seach newegg.
Tab
12,145
Antec, Antec, Antec, Antec! You have to love them :D Li-Lian if your looking at a aluimnium case...
Hagen
27
If you want some advice, spend the extra bucks and go with an aluminum Lian-Li. I did, and don't regret it. Only had it just over a year, and alot more models are out now. It's a beautiful case. lots of room inside for cooling, two intake fans on the front, a blowhole on top and one outlet at the back. I like the case so much, I am planning to keep it for years, and just upgrade my other components. I think the investment in the case is the best move I ever made: www.lianli.com
Cheers,
Hagen
