need a case, please help
Skott
5,730
The Antec Nine Hundred is another possible choice. Like all cases it has its pros and cons. Extremetech just did a nice review on how to help make a case more silent and it used the Nine Hundred in its project. Might want to check it out to give you some ideas.
Zepper
18,998
Blue CoolerMaster Stacker STC-T01 - available at www.SVC.com at $80. after rebate + shipping. You can get a windowed side panel for it and LED fans are cheap - the CM ones are some of the better ones.
.bh.
Boyo
1,406
YOu can get the Lian Li PC7 Plus II with a window for around $100.00. Great case.
Boyo
1,406
