Need a car recommendation
Tret
Well, I've been saving up some cash for a car and have about $3000 to spend on one.
I'm looking into getting a car thats a bit sporty, has a manual tranny, decent gas if possible, and reliability wouldn't hurt either but's it's really not important. One more thing it has to be a decent size since i'm 6'2 265lbs. I was looking at a SHO as well as a Mustang SVO.
So, ATOT decide what my next car is going to be!
Edit: I just want something Reliable and cheap to fix.
I was thinking of a 91-96 Manual Ford Escort
Ford Escort...sporty?😕
I would suggest a Toyota MR2, but it would be a tight squeeze. Fulfills all the other criteria...
I changed my mind on the post forgot to edit that out lol.
Originally posted by: nakedfrog
Yeah, the mid 90s SHOs are pretty decent as far as your criteria.
but wouldnt that porky SHO handle like a pig...i mean those things just look soft... also the 3rd gen didnt have manual tranny, 2nd gen would be pretty rare i guess...
Fast, reliable, cheap
Pick 2 🙂
Mustang SVOs don't really fit any of those 😉. They can be made pretty quick but they are old and weren't super reliable to begin with and are collectable so not cheap unless beat to death. $3k will buy a a 5.0l mustang which is about as close as you can get to getting all three. SHOs aren't all that reliable either.
Pick 2 🙂
cheap,Reliable
Fast, reliable, cheap, practical
Pick 3
Fixed to account for motorcycles.
Fast relaible practical
