Need a burning program that supports CD Text, help
AbercrombieGuy
11
I need a burning program that supports cd text. I have adaptec but I don't think it supports cd text. If it does, how do I use it? If not, what is some software I could get that supports cd text. Thanks.
Ladi
2,084
Please read the reply to your last thread about the same topic...
~Ladi
ThisIsMatt
Banned
Aug 4, 2000
11,820
Easy CD supports it, right before you hit okay to start burning, click the advanced button, select DAO, and select cdtext...
duragezic
11,234
4
Well I've always used Nero and found it to be the best overall burning program. To use CD-TEXT theres a tab at the top and it's easy to find. Just click to enable it and enter Artist/Album. To name tracks just right-click the mp3 after it's dragged over to your cd and goto Properties. Then
