hi
i got an asus probe thingy to monitor the cpu temp
where do i plug it in the mobo. lmk thx...i can't seem to find the 3 pin thing to plug it in...thx ahead of time.
The P2T probe connection is a 2-pin connector, and the pins are located just below and to the right of the Slot A. There are 4 pins there, and the P2T connects to the left pair labeled JTCPU. See page 30 of the manual.
