Need a bit of help on JAVA
Xylitol
public double south(double num3, double num4)
num3 += 24;
num4 *= 2;
System.out.println("num3 / num4 = " + (num3/num4));
return (10 * (num3 + num4));
Thats what it says
I have to find the final output
I know that num3 = num3 + 24 and num4 = num4 * 2
num3/num4 = num3/num4 ????
What good does that do me?
Or am I doing this wrong?
If I am can someone lead me in the right directions
Thanks
Are you referring to:
If so, that is simply printing the result of num3 divided by num4 with the text "num3 / num4" before it.
Yea but as my answer, am I just supposed to leave my answer as numx
x = any #?
num3 += 24;
num4 *= 2;
Thats what it says
Thanks
Wrong forum
But by itself, it outputs nothing. What does "main" say?
uhhh... not sure if I know what exactly you're asking but from the return statement it looks like you're returning something like:
10(num3 + 24 + 2(num4)) or num3 + 2(num4) + 24 (multiplying out and simplifying)
The System.out.println("num3 / num4 = " + (num3/num4)); has no bearing on the return value since it's not reassigned.
