Need a big case!
ShadeZeRO
139
Hey All
I'm in a need of a new case. My Antec 1200 basically worn out now and decided to get something not so rice.
Looking for:
-Clean/sleek Case (Similar to Fractal Design Define XL or A71-F)
-Wire management (Similar to Corsair 800D)
-CPU Heatsink cutout (Simliar to 800D/XL)
-Must fit 9 HDDs (10 preferred).
-Going to install a Corsair H100 (Need space for 240mm RAD)
-Black preferred, but open to anything tasteful.
Suggestions? =)
ElFenix
102,408
8,596
800d with hard drives mounted in the CD bays? (anyone else remember when drives came with those rails?)
ShadeZeRO
139
Would be nice to be able to put in another enclosed bay like this.
Krynj
2,816
8
I have one and it has terrible air flow.
What are your load temps like? I haven't read much about their airflow. My CPU spends a lot of time at 100% usage, so I like a good CPU cooler coupled with a case that allows for plenty of ventilation.
Elganja
2,143
24
800D is probably the best case I have ever owned... my only slight is that the plastic drive lock things break VERY easily as you can see
mine (older PSU, I have a AX1200 in there now):
Lightflash
274
I was looking at the T10 myself. Would be nice to get some Dual LGA2011 love going on in there.
Right now it has my SR-2 sitting in it and it looks small inside the case :eek:. It gives me the room to upgrade from just watercooling my 2 cpus to watercooling my tri-SLI/tri-fire setup and a new dual S2011 board (basically a planned system for late 2011/early 2012 and will use basically every space available, but might have to go to the TX10 if I need more room o_O)
