need a 80 or 90mm fan thinner than 25mm
smartermoney
306
I am building a case and i have overloaded it with 4 10,000 raptors and i need a fan to blow across them to help on cooling. There is a spot on the case between the outside frame and hd frame. It will NOT fit a standard 25mm thick fan. It needs to be less than 19mm thick. I cannot find anything on newegg less than 25mm thick. Any help?
Aso need 2-120mm Blue lcd fans. Shoot me the best to get for cfm and sound (quiet).
mechBgon
Oct 31, 1999
30,699
You can get a thinline Panaflo 80mm fan if you want. Go to DigiKey and do a search for fba fan, then filter for 15mm-thick 12-volt 80mm ones. Or I seem to recall being able to find a Sanyo Denki at... aha, Sidewinder Computers. Not cheap, but hey, neither are four Raptors. Hope that helps :)
Zepper
18,998
smarter to have gotten a case with room for standard fans where you need them - not paying any $18. for a fan that hardly blows more breeze than a flotilla of gnats...
.bh.
