Need a 680i SLI Motherboard recommendation
aka1nas
4,335
Hi all,
I currently have a G0 Q6600 on pre-order and was all set to grab an Abit P35 board. Plans have changed and it now looks like I will also be grabbing a second 8800GTS 640MB for some SLI-goodness along with maybe a beefier PSU(Looking at the Antec TruePower Trio 650W) and a new case(Antec 900). This throws my motherboard choice out the window and now I am back to square one.
My requirements are:
- Needs to be able to fit a Tuniq Tower without major modification
- Can hit around 400Mhz or so FSB with a Quad-core. I already have a 4GB RAM kit that is going in this build and I don't think this stuff will do much above the DDR2-800 that it's rated at. So, a mobo with FSB holes in that general area wouldn't be a great idea.
- Has at least one usable PCI slot for my PhysX card when two GPUs are installed.
- I'd prefer to stick close to the $200 price point, but can be a little flexible.
I've been doing some research on the various 680i models, and they all seem to suck with Quad-cores or they have some horrible flaw, like eating RAM. Has anyone here had reasonable success with the 680i? As I will likely be RAM limited on this build, I really don't need much above 400FSB.
CZroe
24,195
857
What kinds of problems? I think I'm a prime candidate for a 650i considering that all I want is SLi and Quad-Core support with DTS Connect or DD Live. However, I'm going to be doing 4GB on 64-bit Vista so, if there is any problem with these boards (like the 3 of 4GB useable RAM thing), I'd like to know.
aka1nas
4,335
Well, there were some threads on XS about the models based on the reference design eating RAM, and several other models have/had FSB holes with Quads in particular. Gary just did an article yesterday(I didn't see it until after I posted) about all the 680i boards getting BIOS updates for 1333 FSB support, so maybe things are better now.
CZroe
24,195
857
Though I intend to overclock, I intend to do it on a future board that I am just using this to hold me out until then. I guess the FSB O/C dead-zone doesn't concern me too much, but that memory thing sure does. Thanks for the info!
hennessy1
1,901
I would have to recommend the evga 680i a1 version board very good have same setup your looking for 2 7950gx2 with physx card. running a quad qx6700 oc to 3.2ghz
