Need a 6' USB printer cable, which place is best/cheapest?
Svnla
17,986
1,388
First of all, printer makers need to include cable with new printer.
So I checked out monoprice and a 6' USB printer cable is about $5 including shipping.
Any other places that are cheaper? TIA.
Mojoed
4,473
Try a dollar store if $5 is too much for a shipped cable from Monoprice.
coxmaster
3,017
Some do, most dont. Especially on the cheaper models. They havent for years, primarily because people complained that the printers were too expensive and they didnt need another cable laying around that they werent going to use.
As others said, dollar store
Locut0s
22,205
43
This. The computer retail store I work at seels them for about $3-$4, any "good" local computer store would be another option.
tatteredpotato
3,934
I just buy from Monoprice in small lots to keep shipping down. Pick up a bunch or random cables you may need in the future while you're ordering the USB.
FoBoT
63,084
15
fobot.com
i have an extra one if you want to come pick it up
SSSnail
17,458
83
86
You can actually go to your local Ross or Marshalls and pick up one for cheap. Failing that it's monoprice.com
lxskllr
59,551
10,056
BigLots has them. I'm surprised you don't have a collection. I have a drawer full from miscellaneous peripherals I've bought over the years; but none from printers :^D
Locut0s
22,205
43
Seriously dollar stores do carry these. Just saw one today in a dollar store.
Svnla
17,986
1,388
Good suggestion about the dollar store, I will swing by and see if they have one. Thanks for all that replied.
I don't get the picture from Fobot. <scratching head>.
preslove
16,754
64
He is inviting you to his house, where he will then incapacitate you and imprison you in a pit in his basement. He will then lower a basket with a string with lotion in it. Then he command you (using the third person) to put lotion on your skin, or he will spray you with a hose.
Svnla
17,986
1,388
Ah, got it now.
I think Fotbot is confused me with someone else..lol
Yep dollar store, but what kinda ATer doesn't have like 10 extra USB cables? :p
The non nerdy/normal sun loving non pale skin type? :p
