- Nov 24, 2003
- 602
- 1
- 0
Ok, here is my problem. I just bought a Dell 2405 monitor so now ill probably use that instead of my tv in my bedroom to watch dvds. However, the problem is this. I can either use the pc dvd player or the stand alone player to watch them in. If I use the pc dvd player I can use the old 2.1 speaker system I have now but I would have to get up to do any volume adjusting if need be, plus i dont have any way of controlling the dvd since I wouldnt have a remote for the pc.
Now if i use the stand alone dvd player and just use component cables to the monitor then I cant use the pc speakers, but then I have a remote for the player and a way to control the dvd but now way to listen to it.
So do I buy a new set of 5.1 for the pc with a remote to solve the problem of the volume control and still have the problem of no way to control it, or do I use the standalone player and think of some other way?
1. I dont want to buy a new set of bedroom hometheatre speakers, if its speakers, they will be for the pc since i want to use them for games too.
2. Using the standalone player would be easier since I already have a remote, but then can I somehow run the new speakers to it? Then that way I wouldnt have the sound of the pc fans as well.
3. Also, which connection is going to give me better quality, DVI through the pc to monitor or component through player to monitor? I would assume DVI, but who knows....
That is my problem... I would have around $100 safely to spend on the speakers or whatever since i just bought this monitor so what do you think? Im open to options.... maybe just a remote for this little 2.1 system I have? Something from radio shack or something..who knows....
Thanks
Thanks
