Want to jazz up the inside of the case a bit more. Have black/cold cathode light and UV/glowing cables. Looking for a UV/LED lighted (80mm) fan for the HS. HS is an SLK800 on an XP2100+ that will probably be overclocked a bit. I found this one but would like a few more cfm. Looking for around 40cfm or so but also don't want it to sound like a jet engine.
I would appreciate any ideas or links to fan options I should consider.
