I think I've seen these, but can't locate them.... A recepticle for 3.5" hard drives that fits into a 5.25" drive bay, and connects to a USB header on the mobo and takes power from the mobo's power harness. It has a slot in the front that you shove a bare 3.5" hard drive into, turning the HD into a USB drive. You can just push and pull the HD in and out, I think they are hot swappable.
Do these exist? Anyone have a link? Thanks.
Note 1: I am not talking about IDE removable hard drive trays, which I have. On my mobo, anyway, if I swap HD trays (with power off of course), the bios self-configures, which screws up my HD boot sequence, requiring me to go into the BIOS and fix it with each swap
Note 2: This is to use with a number of drives that are used of for off-site storage of backups. I'd rather not spend the $$ for a separate external enclosure for each drive. I have found some IDE to USB rackmounts, but don't want to have to spend the money for a tray for each of the drives.
I may end up using one of the USB to IDE cables that come with a power supply that plugs directly into the HD, but I'd prefer the more elegant solution I've described.
