...would like your advice, please.
I came into some "free money" (and the desktop space) to get a 30-in LG monitor.
Of course, want to use the 2560.1600 native res for gaming. Yes, I would even like to run Crysis at that rate.
I see reviews getting almost 40 fps in Crysis at that level with the new 5970. I could even afford that, but (1) I know bleeding edge vid cards are a bad buy, and (2) you can't even find it for sale at the moment.
So, I ask you: What else would you all suggest for options. Naturally, I'm fully open to combo of other cards, in sli or crossfire, to achieve the desired results.
Up til now, even if I had the money, I was avoiding 30-in display because it took more vid card than seemed reasonable in order to consistently produce the 2560.1600 with full candy settings. Now it is seeming do-able to me. But I need that advice...
P.S. I know this isn't the right forum, but if anybody is interested, I would value input on CPU/MB combos for this build.
Thanks!!:biggrin:
Thanks!!:biggrin:
