Need 120MM 120V Fan
ctk1981
1,464
Anyone know where I can get one? And yes, I do mean 120V.
This is going into an external self contained water cooling rig, want to tie into 120V with the pump.
Thankx in advance.
ChefJoe
2,506
You'd be better off trying to find a power brick from some random piece of hardware and using that to get your voltage. Thrift stores tend to have piles of such power bricks (used for converting AC to DC for electronic gear like cordless phones, hubs, etc...).
But... if you want to spend the $30 on an AC one, there's always digikey.com
http://dkc3.digikey.com/pdf/T032/1032-1039.pdf
ctk1981
1,464
OUCH!!!! Bgmicro has a 119MM for 10.95 ive found....that might be the best bet, or that brick you are referring too. But i need to keep it extra small. This box is 8x8x4 and is already beginning to get cramped.
ctk1981
1,464
Thanks dude, picked one up from there for 12.85 and some other misc items too.
Jeff7
41,596
20
Make sure this thing is away from the monitor; 120v fans put out a lot of EM radiation, which will make your screen turn all weird colors and patterns.
ctk1981
1,464
Its gonna be sitting on the floor about 5 feet away from the desk. Should be good enough no?
Amorphus
5,561
I saw a 120mm metal-cast fan at radioshack the other day... I'm pretty sure it was AC, too...
oh, right, and when you ask for 120v, you should specify "alternating current"
