NECRO ALERT Alternator or battery?
bryanl
1,157
8
The alternator doesn't do squat until the engine is running. So if you are having trouble starting, its likely the battery.
A bad alternator can prevent charging and ruin a battery.
If I didn't have the biggest engine I'd prefer high RC over high CCA since RC appears to correlate better with lifespan.
Advance Auto often has discount coupons, but they may apply only to Internet orders (free store pickup): http://www.coupons.com/coupon-codes/advance-auto-parts/
tortillasoup
1,977
Alternator whine (really more of a whistle) from a bad diode does not come from the engine. It comes through the radio as a result of interference due to the bad diode, but it is not audible from the engine compartment.
A bad alternator bearing can cause sounds like belt whine, and does indicate a need for replacement, but a failed bearing wouldn't cause a low charge rate.
https://www.youtube.com/watch?v=hmPUUVwIJUU
Very clearly diode whine and this is heard externally and not just "through the radio". Diode whine through the radio can easily be caused simply by a bad ground (ground loop) and not necessarily a bad alternator.
