Quick Specs: NEC MultiSync FE950+ (Black cabinet)
Screen 19" (18.0" viewable image size)
CRT Flat Aperture Grille
Maximum Resolution 1792 X 1344 @ 68 Hz
Horizontal Frequency 30 kHz to 96 kHz
Specifications
Picture Tube/Display: 19" (18.0" viewable image size), 90° deflection,
0.25-0.27mm variable grille pitch, medium short persistence
phosphor, totally flat aperture grille CRT,
multi-layered, anti-static screen coating,
dark-tint screen and OptiClear® screen surface.
Input Video Signal: ANALOG 0.7 Vp-p / 75 Ohms Positive
Sync: Seperate sync: TTL Level
Horizontal sync: Positve/Negative
Vertical sync: Positive/Negative
Composite sync: TTL Level, Positive/Negative
Display Colors: Analog Input: Unlimited Colors
(Dependent upon display card used)
Synchronization Range (Automatic): Horizontal: 30 kHz to 96 kHz
Vertical: 50 Hz to 160 Hz
Resolutions Supported: 640 x 480 @ 55 to 160 Hz
800 x 600 @ 55 to 146 Hz
832 x 624 @ 55 to 141 Hz
1024 x 768 @ 55 to 116 Hz
1152 x 870 @ 55 to 103 Hz
1280 x 1024 @ 55 to 89 Hz
1600 x 1200 @ 55 to
