I have the NEC DVD RW ND-2500A drive, along with my Sony CD-RW CRX320E.
The current NEC drive will not work. It basically freezes the drive whenever I try to do something with it.
Inside of "My Computer" it shows the NEC as "DVD-RW Drive" which is 100% correct. However, whenever media is put inside, it changes to "CD Drive"
My Sony drive works fine, no problems at all. Any ideas what might be going on with my NEC? I thought I upgraded the firmware on this awhile ago...
Should I try this: http://drivers.softpedia.com/g...0A-firmware-109a.shtml
Just to add, I am currently using this firmware: http://support.necsam.com/OEM/...rmware/readme.asp?ID=4 version 1.07.
