NEC AS95F 19" Monitor $229.99
Herbman
1,278
NEC AccuSync AS95F 19" Monitor $259.99 at Buy.Com -$30 coupon (all customers)= $229.99. Pretty good deal for a 19" flat screen monitor. Just do a search for 19" monitors should come up on first screen.
loogie
Banned
Oct 18, 1999
2,478
It was the deal of the day today, so you could have gotten it for 220 shipped rather than the 260 shipped. :)
Edit: Just checked the cart, it was indeed the as90.
luv2chill
4,611
90 - .26mm dot pitch, Flat Square tube
95 - .25mm dot pitch, True Flat tube
not a whole lot of difference... getting a truly flat screen might be worth it to you. Keep in mind that you will have to pay shipping on this. If it qualified for free shipping like the 90 (Deal of the day) then it would be really hot!
l2c
DieselMan
2,270
Thanks, luv2chill. The difference for me is about $40 (factoring in shipping) between the two monitors. It'll be mainly for watching DVD's, so the dot pitch won't matter as much (hopefully).
Left nut
Banned
Feb 2, 2000
278
I think the refresh rate at 1600X1200 is 76hz...
Anyone know how this monitor measures up to a NEC FE950?
rootaxs
2,487
Seems the 95F has a .24 dot pitch as opposed to the .25 that Buy.com quotes. Other specs include:
Screen: 19" (18.0" viewable image size) Flat Screen
CRT: 0.24 mm flat dot pitch / 0.20 horizontal
Maximum Resolution: 1600 x 1200 @ 76 Hz
Horizontal Frequency: 31 kHz to 96 kHz
NEC even has an Evaluation unit available for those who wants to test things out first:
Evaluation Unit
