NEC 3500 will NOT work in FW/USB external enclosure.
Chunkee
10,391
But if i put a samsung combo dvd/cdrw in there with ide connected...it works.
what is the deal with that? tried ALL JUMPER SETTINGS ALSO
anyone have similar problems with certain drives in enclosures?
jC
gtd2000
2,731
jC
Dear Gavin:
Thank you for your inquiry.
First of all, please verify the following before recording any CDs or DVDs
1. Copy a data file (excel file, text file) to the disc. Then read the data file from the disc. If it works, then the DVD writer & enclosure are working properly.
2. Most DVD-Videos are in different formats and are copy protected. Please follow below links for more information.
http://www.nero.com/en/FAQs_DVD.html#2
http://www.memorex.com/service...ort/answers.php?cid=14
Normally, if the DVD writer can format a DVDrw disc, then the overall configuration should be working.
SYBA (USA)
Support Team
----- Original Message -----
To: support-us@syba.com
Sent: Sunday, November 07, 2004 5:59 AM
Subject: External 5.25" USB2.0 Enclosure SD-525U2ENC (Myson version)
Dear Sirs,
I just received my enclosure from Acortec and I have installed my Memorex Dual Format X-1 DVD writer.
The enclosure and drive are recognized (and installed) by Windows XP Pro on my Emachines M6810 notebook.
(Enhanced USB support is enabled with SP1 installed)
I can read CDs and DVDs and actually format disks.
I cannot actually record anything though? (Using Nero6, Roxio DVD Creator or NTI 6)
This appears to be a very common issue with external enclosures and DVD writers (which I was not aware of previously).
What do you recommend trying to get the drive to work?
Regards
Gavin
Why do tech support never answer the question or offer useful advice? :|
Chunkee
10,391
I could not get it to work, BUT, I put in my Pioneer 108 and it worked(only through USB not firewire). So the NEC 3500ag is my new internal and my pioneer is my external.
jC
gtd2000
2,731
I just got home and hooked up my external drive using a USB 1.0 hub - guess what?
It works!
The drive that I am using is a Memorex but this is actually a Pioneer 106D.
Now I'm going to try installing some drivers for the USB 2.0 that came on the supplied disk. Not sure how that will work out though :confused:
