I built a computer for my wife using ABIT ST6-RAID and Celeron 1.1A. The machine is overclocked to 133FSB default vcore and is solid. I have MBM and is reporting CPU temps in the range 40 - 44 (Winbond 2 Diode setting). However Sensor-1 (winbond 1) is reporting a temp of 32-37. This I am guessing is the NB temp? So I have ordered a Crystal ORB. I looked at the board and the NB heatsink is puny and is mounted using two spring loaded plastic clips. How can I remove this without destroying the pin. Seems to me the easiest way to get it off is to clip the end off and the pin should come out. This would make this pin will become unusable. Is this the only way to do this? HELP.
