Navy Railgun Superweapon
NetWareHead
THAT guy
Aug 10, 2002
5,847
154
I wouldn't be so sure about that, you'll need a very high fire rate (extremely difficult with a railgun), great targeting (not easy) and very fast response (how fast can you swing the gun barrel around) to make missiles obsolete. Missiles are comparatively cheap.
Well not necessarily with railguns, but with the other weapons I mentioned (directed energy weapons and the like) travel at the speed of light. If we can track an incoming missile or airplane via radar or similar technology, then the technology to target a weapon traveling at speed of light is enough to shoot down that airplane. Technology like this already exists but with fast firing auto-cannon such as CIWS, Goalkeeper and the like. Now replace the multi-barreled autocannon with something else and you can shoot down missiles hundreds of miles away instead of 1 mile away.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Looks like another waste of US tax payers money courtesy of the Military.
Learning about such technology may allow other methods of getting payloads into space. Is that a waste?
Mar 10, 2005
14,647
looks like someone doesn't know what he's talking about.
what ever this costs to develop, the navy will see huge savings and safety when they design a ship around inert warheads and no propellant. this will see a limited revitalization of the battleship as a firing platform, with further massive cost savings over the current fleet.
edit:
that's never gonna happen. nothing worth putting into space would survive the acceleration, and that's just for starters.
11,036
11
They don't just slighshot it up there. It's a survivable acceleration that puts the rocket in a upward path and boosters take up the slack and continues the thrust
Gibsons
12,530
35
edit:
just use a longer barrel. They can already put gps, IR detection, timers etc. on cannon shells.
epidemis
794
I was thinking along the lines of the friction heating it up (like a meteor). I had to look up meteor speeds, I had no idea they went that fast when they entered the atmosphere, but I guess there is a big difference in the temp buildup between a few thousand mph and 30,000 mph.
The energy rises exponentially. (30,000^2-2000^2)/(2000^2)= 2240% more energy per pound
Formula for kinetic energy: 1/2*m*v^2 = E
14,647
there are limits as to what a conventional gun can do. these rail guns exceed those limits - the amount of energy is much greater, the warheads themselves are 100% safe and potentially very cheap hunks of iron, and there is no unstable chemical propellant to handle and foul your gun. the point is, this is a huge step forward for naval warfare.
PlasmaBomb
11,636
Just a smidge... air resistance increases with the square of speed.
OK, what was the thing they fired out of the gun? It looked like a connecting rod or a pittman arm. Did they just look around the floor for some ferrous metal to sling out of it? I wanna see a 5600mph toaster or coffee pot.
It's a test round.
Heat generation is a problem as well. Plasma to the face isn't fun :D
You better believe it :colbert:
NetWareHead
THAT guy
Aug 10, 2002
5,847
154
This. So many warships have been lost or suffered damage due to a lucky hit, penetration in the ship's magazines or careless handling of propellant/shells. (battleships Hood, Arizona & Roma to name a few). By eliminating carrying all of that explosive propellant and switching to an inert round you can eliminate the armor needed over the magazines, if the inert projectile suffers an accident or magazines get penetrated, the inert rounds are not subject to explosion or cook-off.
FallenHero
5,659
Would solve problems like this for sure.
http://en.wikipedia.org/wiki/USS_Iowa_turret_explosion
FallenHero
5,659
wow more convoluted and interesting story than one would think..
Pretty much what I thought when I started reading it. Unreal how the Navy handled the entire incident, from throwing out the evidence needed to reconstruct the entire event to signing off on the report before all the facts were known. Then an outside agency comes in and says they are wrong with science backing them up and the Navy goes "nuh-uh!" like a child.
Gibsons
12,530
35
what? The point I was trying to make is that if you're postulating using a railgun to launch something into orbit, G forces on the projectile are a relatively minor problem.
As for this being a huge step forward - maybe, there's certainly a lot of advantages to it. But it's a long, long way from making this a practical weapon. As I understand it, the expected barrel life right now is under 10 shots. I'd guess they'd need at least a thousand to make it a practical weapon. That or carry a large supply of barrels on board, with a way to rapidly change them out.
jhansman
2,768
29
So, what senator got this contract approved for his constituency? Big boy toys...
Fenixgoon
32,049
10,822
Wow, how does the bullet not vaporize (or at least burn up) at that speed?
because the heat required to vaporize metal is ridiculously large?
melting point of iron is 1538C.
you could definitely vaporize some in impact scenarios, where you get ridiculously complex frictional interactions.
gorobei
3,768
1,209
the primary benefit is no propellant storage onboard (no risk of explosion, no need for extra armor to protect, simplified construction, reduced overall ship weight = lower costs all around)
while ship to ship combat may change if this is the default weapon, the primary role for something like this would be ship to shore bombardment. A projectile moving this fast with a guidance system like on the currently developed smart artillery could effectively replace our tomahawk missile systems. "need to place a precision strike on a uranium enrichment centrifuge 50 miles inland? we can do that". no radar warning system or sam system is going to be able to intercept these things.
