My motherboard will run at 100 133 but not 166 stable. Memtest show no errors on 100 or 133 but does at 166. Is it the memory of the motherboard? I dont have another of either to test them with. Or is it simply bios timing settings?
N2U400 Motherboard
Corsair 3200 value select
XP2500
Gefore 5200
40 GB WD pata
Nec DVDRW
I wont be able to check back till tomorrow but thanks in advance for you sugestions or opions.
N2U400 Motherboard
XP2500
Gefore 5200
40 GB WD pata
Nec DVDRW
