I have a squier acoustic guitar and I was wondering if I could alter the distance from the strings to the fretboard myself, or do I have to take it to a music shop and have it done? I see that there is a bolt inside the guitar protruding from the neck that looks like it would take an allen wrench. Would that adjust the distance between the neck and the strings? The reason I ask is that when I hold the guitar up and look down the length of the neck from the side, the distance from the strings to the fretboard increases as I move up the frets. Is that normal for a guitar, or can/should the distance be the same everywhere? I find it difficult to play barre chords on the 1st fret because the strings are so close to the fretboard, but they are much easier on the higher frets. Can I make it so I have more space between the strings and the fretboard on the 1st fret, or am I SOL on this and just need to practice more?
