My last overclocked system was an opteron 939 system with DDR memory. Now I have an AM2 3800+ with 2GB DDR2 PC-5300 ram. When I run CPUZ it says the mem is running at 300mhz and the CPU bus speed is 200mhz. Does this means I can bump the bus speed on the CPU to 300mhz before I have to worry about the ram being overclocked? If I raise the bus speed, will the mem speed go up automatically? How do I change the Bus to memory speed ratio?
Thanks in advance for the help.
