MythTV Motion Blur issue
Tal
Hey all, appreciate some help for a Myth newbie.
I've got this system setup:
Sempron 3100
ECS Nforce3 MB
512MB DDR 400 RAM
ATI FireGL X1 128MB
Audigy 2
2x 250GB 7200 RPM hard drives
I'm outputting to an Infocus Screenplay 5000 projector. I'm running Fedora Core 4. The Motorola STB is connected via firewire and seems to record just fine.
When I playback a recorded show, I seem to have lots of motion blur. I've tried enabling Kernel mode de-interlacing via the mythfrontend setup, and that seems to help a bit, although it introduces a slight hicup every so often. When I copy an .NUV file over to a PC, and play with Media Player classic, I see a bit of motion blur, but not so much as I see in Mythfrontend on the projector. What can I do? Is it something with my xorg.conf? Is it something with the default Myth recording profile? Below is my xorg.conf file. Thanks in advance.
(Oh yeah, I'm running the latest ATI FGLRX driver for the FireGL as well.)
----------------------xorg.conf-------------------------
# File: xorg.conf
# DRI Section
Section "dri"
# Access to OpenGL ICD is allowed for all users:
Mode 0666
# Access to OpenGL ICD is restricted to a specific user group:
# Group 100 # users
# Mode 0660
EndSection
# Module section -- this section is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
Load "dbe" # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
# This loads the Type1 and FreeType font modules
Load "type1"
Load "freetype"
# This loads the GLX module
Load "glx" # libglx.a
Load "dri" # libdri.a
EndSection
# Files section. This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
FontPath "/usr/X11R6/lib/X11/fonts/local/"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
# FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
# The module search path. The default path is shown here.
# ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received. This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
# Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
# Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences. This allows clients to receive these key events.
# Option "Dont Zoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
# Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
# Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
# Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
# Option "AllowNonLocalModInDev"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
# Option "Protocol" "Xqueue"
Option "AutoRepeat" "500 30"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
# Option "Xleds" "1 2 3"
# Option "LeftAlt" "Meta"
# Option "RightAlt" "ModeShift"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# Option "XkbModel" "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# These are the default XKB settings for XFree86
# Option "XkbRules" "xfree86"
# Option "XkbModel" "pc101"
# Option "XkbLayout" "us"
# Option "XkbVariant" ""
# Option "XkbOptions" ""
# Option "XkbDisable"
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Device" "/dev/input/mice"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
# Option "BaudRate" "9600"
# Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
# Option "Emulate3Buttons"
# Option "Emulate3Timeout" "50"
# ChordMiddle is an option for some 3-button Logitech mice
# Option "ChordMiddle"
EndSection
# Other input device sections
# this is optional and is required only if you
# are using extended input devices. This is for example only. Refer
# to the XF86Config man page for a description of the options.
# Section "InputDevice"
# Identifier "Mouse2"
# Driver "mouse"
# Option "Protocol" "MouseMan"
# Option "Device" "/dev/mouse2"
# EndSection
# Identifier "spaceball"
# Driver "magellan"
# Option "Device" "/dev/cua0"
# EndSection
# Identifier "spaceball2"
# Driver "spaceorb"
# EndSection
# Identifier "touchscreen0"
# Driver "microtouch"
# Option "Device" "/dev/ttyS0"
# Option "MinX" "1412"
# Option "MaxX" "15184"
# Option "MinY" "15372"
# Option "MaxY" "1230"
# Option "ScreenNumber" "0"
# Option "ReportingMode" "Scaled"
# Option "ButtonNumber" "1"
# Option "SendCoreEvents"
# EndSection
# Identifier "touchscreen1"
# Driver "elo2300"
# Option "MinX" "231"
# Option "MaxX" "3868"
# Option "MinY" "3858"
# Option "MaxY" "272"
# Option "ButtonThreshold" "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "Monitor0"
HorizSync 31.5 - 37.9
VertRefresh 59.9 - 60.1
# === mode lines based on GTF ===
ModeLine "ATSC-720-60p" 74.16 1280 1320 1376 1648 720 722 728 750
#ModeLine "ATSC-720-60p" 74.25 1280 1320 1376 1650 720 722 728 750
ModeLine "ATSC-1080-60i" 74.25 1920 1960 2016 2200 1080 1082 1088 1125 Interlace
ModeLine "ATSC-1080-60p" 148.5 1920 1960 2016 2200 1080 1082 1088 1125
Modeline "720p" 73.825 1280 1320 1368 1640 720 722 724 751 +hsync +vsync
EndSection
# Graphics device section
# Any number of graphics device sections may be present
# Standard VGA Device:
Section "Device"
Identifier "Standard VGA"
VendorName "Unknown"
BoardName "Unknown"
# The chipset line is optional in most cases. It can be used to override
# the driver's chipset detection, and should not normally be specified.
# Chipset "generic"
# The Driver line must be present. When using run-time loadable driver
# modules, this line instructs the server to load the specified driver
# module. Even when not using loadable driver modules, this line
# indicates which driver should interpret the information in this section.
Driver "vga"
# The BusID line is used to specify which of possibly multiple devices
# this section is intended for. When this line isn't present, a device
# section can only match up with the primary video device. For PCI
# devices a line like the following could be used. This line should not
# normally be included unless there is more than one video device
# installed.
# BusID "PCI:0:10:0"
# VideoRam 256
# Clocks 25.2 28.3
EndSection
# === ATI device section ===
Section "Device"
Identifier "ATI Graphics Adapter"
Driver "fglrx"
# ### generic DRI settings ###
# === disable PnP Monitor ===
#Option "NoDDC"
# === disable/enable XAA/DRI ===
Option "no_accel" "no"
Option "no_dri" "no"
# === misc DRI settings ===
Option "mtrr" "off" # disable DRI mtrr mapper, driver has its own code for mtrr
# ### FireGL DDX driver module specific settings ###
# === Screen Management ===
Option "DesktopSetup" "(null)"
Option "ScreenOverlap" "0"
Option "GammaCorrectionI" "0x00000000"
Option "GammaCorrectionII" "0x00000000"
# === OpenGL specific profiles/settings ===
Option "Capabilities" "0x00000000"
Option "CapabilitiesEx" "0x00000000"
# === Video Overlay for the Xv extension ===
Option "VideoOverlay" "on"
# === OpenGL Overlay ===
# Note: When OpenGL Overlay is enabled, Video Overlay
# will be disabled automatically
# Option "OpenGLOverlay" "off"
Option "OpenGLOverlay" "on"
# === Center Mode (Laptops only) ===
Option "CenterMode" "off"
# === Pseudo Color Visuals (8-bit visuals) ===
Option "PseudoColorVisuals" "off"
# === QBS Management ===
Option "Stereo" "off"
Option "StereoSyncEnable" "1"
# === FSAA Management ===
Option "FSAAEnable" "no"
Option "FSAAScale" "1"
Option "FSAADisableGamma" "no"
Option "FSAACustomizeMSPos" "no"
Option "FSAAMSPosX0" "0.000000"
Option "FSAAMSPosY0" "0.000000"
Option "FSAAMSPosX1" "0.000000"
Option "FSAAMSPosY1" "0.000000"
Option "FSAAMSPosX2" "0.000000"
Option "FSAAMSPosY2" "0.000000"
Option "FSAAMSPosX3" "0.000000"
Option "FSAAMSPosY3" "0.000000"
Option "FSAAMSPosX4" "0.000000"
Option "FSAAMSPosY4" "0.000000"
Option "FSAAMSPosX5" "0.000000"
Option "FSAAMSPosY5" "0.000000"
# === Misc Options ===
Option "UseFastTLS" "0"
Option "BlockSignalsOnLock" "on"
Option "UseInternalAGPGART" "yes"
Option "ForceGenericCPU" "no"
BusID "PCI:1:0:0" # vendor=1002, device=4e47
Screen 0
# Option "MetaModes" "720p"
EndSection
# Screen sections
# Any number of screen sections may be present. Each describes
# the configuration of a single screen. A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
Identifier "Screen0"
Device "ATI Graphics Adapter"
Monitor "Monitor0"
DefaultDepth 24
#Option "backingstore"
Subsection "Display"
Depth 24
Modes "720p" "1280x720" "1024x768"
ViewPort 0 0 # initial origin if mode is smaller than desktop
# Virtual 1280 1024
EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present. Each describes
# the way multiple screens are organised. A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option. In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
Identifier "Server Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens. The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen.
Screen "Screen0"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used. Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
### EOF ###
Projectors are slow. This most probably is where the motion blur comes from.
The rest is the MPEG "compression" (reduction actually) rate you set in the backend. The lower the data rate, the smaller is the maximum delta between one frame and the next. So if something moves fast in a low quality MPEG stream, then you'll see artefacts that resemble motion blur.
