I climbed under my wife's '06 Equinox today to change the oil and was greeted by this site...
http://v6stqa.bay.livefilestore.com...rNJa3T2YS474C8c4OjgMSmvCjdhOr/oil1.JPG?psid=1
There's oil sprayed all over the bottom side of the engine area. It's fresh as indicated by the driping oil coming off a low hanging piece. There's two tubes coming out from the area in question (some sort of return lines?) and one of them is covered and the other isn't. Circled in the picture above.
The engine was down almost 2 quarts (out of a volume of 4) so it's losing a decent amount. This wasn't here 3,000 miles ago when I last changed it.
Here's a zoomed out pic to see the spray pattern:
http://v6stqa.bay.livefilestore.com...YfvJeZ3SETeR7N_iG6DpXZT_DYq1I/oil2.JPG?psid=1
It's a long, long ways away from the drain plug so I can't blame that a leaker.
Anyone know what those tubes are if that's maybe a source of the problem?
[EDIT]
More info: It's got 77,000 miles on it and had the lower intake manifold and exhaust valves replaced last fall by the dealer...
[EDIT]
