- Jun 30, 2004
- 16,632
- 2,027
- 126
I'm losing my endurance of perseverance in my old age.
The situation:
Household LAN, gigabit ethernet, old Linksys internet-router-switch, Linksys switches connecting upstairs and downstairs on gigabit with CAT-5 cable-drop.
Windows Home Server -- all systems "go" -- recognizes all machines, working perfectly
Two VISTA-64 systems: Haven't tried it on the second (a gamer), but the first machine connects to a system upstairs via RDC, which in turn runs XP Pro SP3. LLTD had been installed before adding SP3. There had been initial difficulties setting up the connection, but not "mysterious ones."
From the same VISTA-64, I've been trying to connect to a second machine upstairs -- running XP Pro SP3. LLTD wasn't installed before SP3. However, the VISTA "sees" the computer and the shared folders and printer.
But when I attempt to log on to the second XP system via RDC, I first get the "authentication" warning, and the dialog box just returns to an active "connect" button -- no window pops up. Same when I attempt to use RDC from the WHS system to connect to the second XP system.
I checked all the settings -- cannot find something that is different from the first XP machine. And also, I can connect from the XP machine to the VISTA machine through the XP's RDC. User accounts appropriate to the connections have been added to the XP system. And also -- I can't connect from the problem-free XP machine to the second XP machine via RDC. In other words, this is not a "VISTA" problem.
What gives here? I don't want to spend the remaining years of my decrepit life slogging upstairs and downstairs to manage that bleeping system.
The situation:
