Mysterious problem with Specific Counter Log of Win XP...
Hi all!
For the last 2 months, I became accustomed to measure the performance of my PC using the LOG COUNTERS of Win XP.
One of the items that I like to check up is the Usage of Physical Memory (this utility inside Win XP is excellent, because it generate a log file with the informations we need). Well, my problem began last week, when, suddenly, with no apparent reason, It disappeared and I could no more to measure it.
It's difficult to explain, but, for who got used to handle these "log counters" that I said, perhaps it would be easier to understand me: Into My Computer icon - Management - System Tools - inside Logs and Performance Alerts, there is one item called Counter Logs. Inside it, we can create new Logs Configs, and we can choose the item that we want to check up (by option "adding counters"). So, there is one list of Objects of Performance, where you can choose what item you want to control. But my item called MEMORY disappeared! This item is (WAS) between Logical Disk and Navigator...
Anyway, it seems very strange, because looks like this specific item is missing... I can conclude that it is a software issue (into Win XP), because everything is running fine here. I tried the RESTORE POINT, but, no success...
So, my question is: How (if possible) can I to add this item (MEMORY) to this list (OBJECTS OF PERFORMANCE), again??...
My PC basic spec is:
- Processor: P4 2.8 533 MHz
- MoBo: Asus P4SDX
- RAM: 1.024 MB DDR 333 (Kingston Value Ram) - 04 sticks of 256 MB each one.
- Gigabyte Radeon 9600 XT
- 02 HDDs: 01 Maxtor 120 GB, 7200 rpm, ATA-133 + 01 Seagate 40 GB, 7200 rpm, ATA-100
- OS: Win XP PRO SP1
Any information/HELP would be very appreciated!
Thanks in advance!
Thanks for your reply, spyordie007!
I have read the content of your link, and it seems that this article match with my issue... But, unfortunately, as I am not an expert, I think that it is a bit confused... And, the worst, it seems that is necessary to handle with the Windows Registry, what is a pain!... I do not like to handle anything there, because I am not an expert on these matters, and, therefore, it can be dangerous...
Anyways, thanks a lot for your link and your attention, spyordie007!
I will keep trying to find another alternative way (if possible) to fix this issue (and I hope that I will not need to handle with Registry...). I have another PC that is OK; I would like that I could to copy some (incorrupt) file(s) to that which is with this issue...
Thanks in advance to anyone for any additional information/help!
