"Mysterious" AMD launch (Mobile Kaveri APUs under FX)
monstercameron
3,818
Unless the A6-7000 is just really bad silicon maybe. It probably is a salvaged die that has the other parts still physically there, and I think some of those parts even if not in use can still take energy. Also, for the A6-7000 to have a lower speed and half the cores on the GPU/CPU, it must really be the 'worst' part from the finished wafer other than completely unusable parts.
*edit - I don't think it is so much that the FX-7500 needs only two watts more for doubling up everything and faster clocks so much as the silicon in the A6-7000 needs the 17 watt TDP just to run as it does due to manufacturing defects.
this is pretty simple, the 17W part will most likely keep higher clocks for longer while the 19W part will throttle more.
Fjodor2001
3,989
440
The AMD AMDs have a larger iGPU than the corresponding Intel Haswell U-series. Also, the TDP is measured with both the iGPU and CPU cores active.
So for CPU intensive tasks where the iGPU is not used much, could it be that the actual power consumption of the 17/19W AMD APUs is comparable to the 15W Intel Haswell U-series chips?
Enigmoid
2,907
31
It is likely the exact opposite. The igp kaveri has is vastly more efficient. Look at beema/mullins.
You are comparing 22 nm FinFET vs. 28 nm planar. Haswell has the integrated IVR and PCH.
IVB/HW ULV CPU is tremendously efficient. The igp is the main power user.
Looking at notebookcheck results a 15W tdp fits 2 HT core running prime95 anywhere from 2.2-2.6 ghz. That includes the PCH.
TreVader
2,057
I dont believe there is that much radiation if at all in that orbit, otherwise you wouldnt have humans stay for long periods of time in the ISS.
They could easily just shield it. The most important thing about getting something to the ISS is weight and the second most important is volume.
Fjodor2001
3,989
440
Your correct that Intel has more efficient CPU, and AMD more efficient iGPU.
But even taking that into consideration, I think the AMD iGPUs are usually larger than the Intel ones. I.e. they devote more of the transistors and power consumption to the iGPU. The end result is higher iGPU performance on AMD APUs.
Also, the graph you showed does not display power usage, but energy usage to complete a certain task. So CPU A can have lower energy usage than CPU B, but CPU A can still have higher power consumption than CPU B. I.e. that would mean that CPU B takes longer time to complete the task than CPU A.
Finally, you only showed energy consumption for one type of workload. What does it look like for other types of tasks? And when comparing mobile CPUs (perhaps including AMD Beema/Mullins), instead of desktop CPUs as you did?
NostaSeronx
3,701
1,230
So SOI wasnt the POS every usual suspect here claimed it was? Good to know ;)
The benefit of SOI is less current for the same performance. The issue in particular is with PD-SOI which by the 45nm needed more voltage to hit the same performance. That issue grew with PD-SOI when shrunk was caused by the floating body which sapped off most of benefits of having SOI. PD-SOI's performance isn't relative to FD-SOI's performance, so you can't compare PD-SOI to FD-SOI unless you are only comparing SOI wafer costs. PDSOI has thick insulator while FDSOI has thin insulator, the cost with FDSOI optimized wafers is lower than PDSOI. While the cost of transportation of wafers for FDSOI is higher than PDSOI.
Just a reference to what happened this is by no means accurate:
Bulk:
1 GHz - 3 GHz targets; 0.8v - 1.2v (High Current)
PD-SOI:
1 GHz - 3 GHz targets; 1.1v - 1.5v (Medium Current)
FD-SOI:
1 GHz - 3 GHz targets; 0.6v - 1.0v (Low Current; to hit low current RBB/FBB optimization is needed)
FinFET:
1 GHz - 3 GHz targets; 0.5v - 0.9v (Extremely High Current)
Shivansps
3,875
1,530
Jaguar is substantially better performance than Bobcat. In fact it has higher performance than silvermont both in performance and IPC.
No, the IGP was a bit better, but thats all, dual jaguars where even worse(1ghz ones) than dual E-350 bobcats, quad jaguars was better because of more cores. Dual Silvermont are better than dual jaguars too, quad jaguars are better than quad silvermont only on igp.
AtenRa
14,003
3,361
No, the IGP was a bit better, but thats all, dual jaguars where even worse(1ghz ones), quad jaguars was better because of more cores.
Jaguar is faster Clock to Clock than Bobcat, so a dual core 1GHz Jaguar is faster than dual core 1GHz Bobcat.
TreVader
2,057
Disappointed that they would resurrect the FX nomenclature on an APU vs a high performance 3 and 4 module processor.
If they manage to put it in a ultrabook it could offer performance equivalent to some mobile i3 and certainly much better gaming performance than anything short of Iris and Iris Pro.
Shivansps
3,875
1,530
Im sorry, but oems stopped using E-350 in favor of A4-1250 in 11.6" models, that resulted in abysmal performance.
And by the time Jaguar was launched, C-50 was not longer used either, both the C-60 and C-70 had turbo enabled and it was kicking in when used in 14" laptops, thats why Lenovo did not wanted to "upgrade" to jaguar on their cheap models and stick with C-60 and C-70.
There is a reason of why Celeron ULV became popular on low end and Bobcat was still used after Jaguar launch, and its not because Intel was paying everybody.
rainy
512
433
AtenRa
14,003
3,361
E-350 was Dual core 1.6GHz 18W TDP + FCH A50M (5.9W TDP) resulted in more than 22W TDP package.
C-60/70 are dual cores 1GHz base with 1.3GHz turbo at 9W TDP + FCH A68M (4.7W TDP) resulting in more than 13W TDP package.
A4-1250 is a dual core 1GHz 8W TDP SoC, no need for FCH chip. CPU performance was comparable to C60/70.
A4-1350 is a Quad-core 1GHz 8W TDP SoC and A4-1450 is a Quad-Core 1GHz base with 1.4GHz Turbo 8W TDP SOC.
Dual core Jaguar A4-1250 didnt replace E-350 but C60/70.
ninaholic37
1,883
31
Interesting. So the main advantage of A4-1250 over C60 is that they turned it into an SoC, saving ~5W.
How about Beema/Mullins? The successor to A4-1250 should be E1-6010, right? Which is 1.35GHz/10W (0.35GHz upgrade, 2W higher), so this time they're actually aiming for improved performance instead of better power?
Sounds like a Tick-Tock cycle (Jaguar being a new arch, Beema improving it).
NostaSeronx
3,701
1,230
The successor to the A4-1250 is the E1 Micro-6200T
Order of progression:
2010 - http://www.notebookcheck.net/AMD-C-50-Notebook-Processor.40960.0.html
2011 - http://www.notebookcheck.net/AMD-C-60-Notebook-Processor.51806.0.html
2012 - http://www.notebookcheck.net/AMD-C-Series-C-70-Notebook-Processor.82852.0.html
2013 - http://www.notebookcheck.net/AMD-A-Series-A4-1250-Notebook-Processor.92891.0.html
2014 - http://www.notebookcheck.net/AMD-E-Series-E1-Micro-6200T-SoC.115414.0.html
C-50 is replaced by C-60.
C-60 is replaced by C-70.
C-70 is replaced by A4-1250.
A4-1250 is replaced by E1 Micro-6200T.
bunnyfubbles
12,248
for me -even though multithreaded s/w support is spotty at best- give me 16-32 puma+ cores vs 4 steamroller modules+tonnes of cache. Why? if mantle/dx12 is the way forward then fast cpus wont be the end all be all as they are with the current driver module. As for general software, more and more things get multithreaded, also just multitasking will benefit.
example scenario:
playing a game, recording it locally, encoding and streaming in online, multiple browser tabs open on a 2nd or 3rd monitor...not saying this couldnt be done efficiently now with a fx8350 but 16-32 puma+ cores @3ghz would do just fine, that is if it is priced at ~$200
ah, so you'd be willing to trade the ability to pleasurably play games now for the possibility of having mediocre to subpar performance years from now
Shivansps
3,875
1,530
Who cares about that? go and tell OEMs that, not me, E-350 was present on 11.6" netbooks, hell, before that they even used Neos that was CPU+NB+SB on +11.6".
C-XX where suppoused to be used on 10", but also offered on some 11.6" as a cheaper option.
When Jaguar came out, A4-1250 launched on 11.6", reemplacing E-350, A4-1200 launched on 10" reemplacing C-XX, like it or not, dont bother me with TDP numbers.
A6-1450 was the one that was good, but also very rare i think only Acer launched 1 model, and there was maybe one or two 11.6" with a A4-5000. You are trying to compare that with the widely used E-350 on 11.6"
monstercameron
3,818
who says a 3ghz puma+ core can't "pleasurably" play games now?
and secondly have you seen mantle? I don't see how you can conclude that games will run subpar on such a theoretical apu? Mantle -and by extension dx12- will alleviate many bottelnecks in the graphics pipeline and allow for the possibility of better multithreading, which the MOAR COARS strategy can take advantage of.
so yeah I would sacrifice single threaded perf for more cores and better multitasking and multithreading!
Shivansps
3,875
1,530
who says a 3ghz puma+ core can't "pleasurably" games now?
agreed, but thats not gona be important for at least 2 years, by them Puma+ will be nothing.
Homeles
2,580
Nice, is that enough to make 32nm and bellow IC malfunction ??
I'm sure the answer's yes, but in the sense that even the processors we use will have errors on occasion due to natural background radiation. Of course, the chance is exceedingly rare...
On the ISS, where the exposure is much higher, they might run into issues with their personal laptops bluescreening on occasion, particularly when the "solar weather" isn't in favor of proper electronic function. But they'll probably be fairly stable.
I definitely was a bit out of line with my claims earlier in regards to Kaveri not working on the ISS. I think there's a good chance that AMD will "launch Kaveri from space." AMD probably gave a few of the guys up there some Kaveri laptops. Such personal equipment isn't mission critical, so they don't need to be rad hard. What definitely isn't happening is Kaveri powering the ISS.
I read a slide earlier on Intel's soft error rate with their 22nm process when exposed to alpha radiation emitted from a piece of radioactive foil, as I wanted to check on my claim that FinFETs are less susceptible than planar. While I still believe this is the case, Intel claimed that a major factor in the 22nm process's innate protection was the dense metal stack, which would potentially mean that such shielding would grow over time as more layers are added, despite the transistors themselves being more susceptible due to their decreased size.
10,451
642
"Out of this world (or atmosphere at least) performance", or maybe just "out of touch". They wouldnt seriously use such a juvenile, meaningless gimmick to announce a product would they?
Homeles
2,580
This is AMD we're talking about. They've done stuff like this before. The "Ruby" video back when they announced Bulldozer (I think?) was really embarrassing.
