I am installing it for an Intel Core 2 Duo E6300. I have the 2 mounting brackets installed on the mobo. For this CPU I believe I have to use the mounting bar with only 2 screw holes. Whenever I go to screw the mounting bar on, the other side that I havent screwed in yet will not be able to reach the hole. I did try doing this in a pattern where you screw a tiny bit on each end back and forth, but it still will not work.
Do any of you have this cooler? It seems like it's a great cooler, but I cannot mount this thing.
Any suggestions?
THANKS!
Any suggestions?
THANKS!
