My XP system won't defrag/scandisk!! HELP! Using Diskeeper Workstation 8.0.478
NFS4
47
OK, I just did a clean install of of Windows XP and installed DKW as I always do. Well, I set it to do a boot-time defrag with all the options checked (included a Scandisk before hand).
But it WON'T do a Scandisk and it won't defrag. When it reboots to do the Sandisk, it says "Volume cannot be accessed, may be locked by another operation..." Then it tries to go through with the defrag and it says "Volume is Locked"
Then when I get into windows and try to do a defrag from there, it says that it can't do one b/c Scandisk has to be run and is asks me if I want to schedule a boot-time Sandisk. And thus starts the never ending loop of going NO WHERE!!
I don't have anything out of the ordinary installed so I don't know what's up. I tried uninstalling DKW and that didn't help. I tried reinstalling DKW, no go. When I go to try to do a boot-time defrag now, the chkdsk option says this:
"CHKDSK is currently set to run on this volume, either by the operating system, or by an application."
