So I buy a new Netgear 108 mbps router, and before this, everything was fine, I could connect to my neighbor's connection no problem 😀 But however, after trying to install this new router, on the wireless network settings, it says:
"Windows cannot configure this wireless connection"
"If you have enabled another program to manage this wireless connection, use that software."
It's happened for all other wireless connections everywhere else now, and i don't know what to do. Do I reinstall something? I know the router works, as i've gotten a wired ethernet connection going through it right now, but I can't seem to configure it for wireless.
I'm using the Intel Pro 3945 btw
