NINaudio
Side, close up, with flash
Side, flash with
Side, from above, with flash
Front, all opened up, with flash
Front, all in place, with flash
The following pics are without the flash on. The LED fan is actually purple, but it always comes out blue in my pics, as do the purple highlights on the water tubing.
Side, close
Side
Side from above
Front, all in place
The radiator is set up with 2 fans in a push/pull configuration.
Loop goes from pump>cpu>gpu>chipset>radiator>reservoir>pump
My temps are (idle/load):
CPU: 34-36/41-43
GPU: 43-44/49-50
Case: 18-20/21-22
Side, flash with
Side, close
Side
Side from above
Front, all in place
CPU: 34-36/41-43
GPU: 43-44/49-50
Case: 18-20/21-22
