Im not sure if im completly correct on this, but doesn't S-video also carry the sound information?? If I was going to connect my computer to my AV Receiver. Would it be better to use just this S-video cable for video and sound? or use the Radeon just for video to the system, and use my sound card for the sound transfer. I have an Audigy OEM,Radeon 8500 REtail, and a Sony Receiever. Also a TV with only RCA inputs.
What would be the best way to connect my systems together?
My Receiver is the STR-SE591 500w System. Has optical,digital coax,rca input and outputs. IS DTS,DD ready. Has 5.1 speaker system attached.
I was thinking of using a COAX cable, and a mini adapter from the Audigy Digital out and sending it to my system for surround sound, when I play DVD's on my system.(USing Windows XP so it should work)
As for the video I would send it from my computer through S-video cable? to the receiver. There, I would just have the video from the receiver output it through a RCA connocter to my TV. IS this wise? or should I send the video line strait to the TV. Which one would give less distortion.
Computer--Receiver 12ft.
receiver-TV 3-4ft
Computer-TV 14 FT
Any Audio/Video Experts out there care to help me with the best configuration?
I hope I explained my setup well enough. Cables cost alot, and I want to know exactly how I want to run what, before I go out buying them.
3 sites I have looked through
http://www.svideotorca.com/
http://www.cablestogo.com/
http://www.bestbuy.com
I was hoping to play DVD's through computer and have surround sound on my system while watching it on TV.
As well as being able to use the speaker setup for Counterstrike.?
I would be gratefull for any kind of advice. I know this is a lengthy post but Plz Try
receiver-TV 3-4ft
Computer-TV 14 FT
