My toilet was a little dirty
rayray2
871
so i grabbed a wad of toilet paper off the roll, dipped it in the toilet bowl and wiped it down. The entire job was completed in about 10 seconds. If I would have went and got gloves, a sponge and some cleaner, that would've taken at least a minute or two. is that smart or am i white trash?
Baked
36,052
17
Should've just scrape it off w/ your nails then lick it off afterward.
Jeff7
41,596
19
:music:
I'd rather clean
All the bathrooms in Grand Central Station
With my tongue
Than spend
One more minute
With youuuuuuu
:music:
FDF12389
5,234
7
Why not use a toilet brush and some spray cleaner? Gloves are unnecessary but cleaner should be used imo.
Engineer
701
Should have used your head (literally). Your hair would have made an excellent toilet brush. Try it next time.
walrus
1,544
13
How to Clean the Toilet
Put both lids of the toilet up and add 1/8 cup of pet shampoo to the water in the bowl.
Pick up the cat and soothe him while you carry him toward the bathroom.
In one smooth movement, put the cat in the toilet and close both lids. You may need to stand on the lid..
The cat will self-agitate and make ample suds. Never mind the noises that come from the toilet; the cat is actually enjoying this.
Flush the toilet three or four times. This provides a "power-wash and rinse."
Have someone open the front door of your home. Be sure that there are no people between the bathroom and the front door.
Stand behind the toilet as far as you can, and quickly lift both lids.
The cat will rocket out of the toilet, streak through the bathroom, and run outside, where he will dry himself off.
Both the commode and the cat will be sparkling clean.
Casawi
2,366
Ok you didn't clean no damn toilet. You just made it look like a toilet should look like,
