My system sucks 10,989 ORB!
Whizzz
16
3DMark 05 ORB
10,989
http://service.futuremark.com/compare?3dm05=820315
Super PI contest (Anandtech)
25.05 ms
http://forums.anandtech.com/messageview.cfm?catid=28&threadid=1489255
The system
http://ca.pg.photos.yahoo.com/ph/thellendfamily@rogers.com/my_photos
I guess I shouldn't complain about my score, but I will.
With the equipment I have I should be getting over 11,000.
I've tried everything to get it, but no go.
The heart of my system;
BIOS Version 1007
Windows XP SP2
A8N-SLI Deluxe
AMD FX55
2x-XFX Geforce 6800 Series GPU (PVT45FUD) Video cards.
G.Skill 4 X 256 PC 3200 - 2-2-2-5 PC 4400 - 2.5-3-3-7
2x-74 Gig Raptor SATA hard drives RAID0 on NVidia Raid (270 MB/s Data transfer rate).
LG GSA 4040B DVD (Cheap, I know I need a newer one)
Enermax 3 in 1 24 Pin (EG651P-VE) 36 Amps at 12V+ Single Rail. Version 1.3
Other system components;
2x-19" Viewsonic Ultrabright E90f+
57" LG Widescreen TV with DVI (RU-50NZ60) for gaming
Logitech Z 5300 Speaker system 5.1
2x- Logitech Wingman Force 3D (863174-1000)
2x-MI Hip Gear, Hip Hop Steering Wheels and pedals (LM571)
Winfast TV/FM card
USB 2.0 4 port card
APC 650 Watt Backup System
TPS 2 Telnet power switch
Cooling;
Koolance EXOS System 1/4 inch tubing
2x-NV2 L06 GPU coolers
GPU 180 for the chipset
CPU - Prometia Mach II GT
My current settings are;
Hypertransport Link - 1060 MHz
Memory Bus - 500 (DDR) MHz 250 MHz X 2
PCI Express bus - 3000 MHz
PCI Bus - 33.3
CPU Multiplier - 13.0x
CPU Speed - 3256 MHz
GPU core - 450 MHz
Memory core - 1.200 MHz
HT Link Multiplier - 4X
CPU Voltage -1.66
DDR Ram Voltage - 2.9V
PCI=E 119 MHz
RAM Timing;
Frequency - 500 MHz
FSB DRAM CPU/13x
CAS Latency - 2.5 Clocks
RAS to CAS Delay - 3 Clocks
RAS Precharge 3 Clocks
Cycle Time TRAS - 7 Clocks
Bank Cycle Time TRC - 11 Clocks
DRAM Idle Timer - 16 Clocks
Whizzz
2Xtreme21
7,044
Yeah man, your system blows. You should dump at least another $4000 into it to make it not suck. -_-
msi1337
7,825
79
101
can we move this to brag and moan?
if you have all that stuff and your still not happy, then you need a new hobby
:cool:
thegimp03
7,420
Wahhhh you're 11 points off. SIGH
Nice system though, I personally wouldn't waste that much money on a computer that's already outdated. To each his own, though.
Whizzz
16
Well, I used my water chiller system (freezer with washer fluid and pump) and got 11, 389 today.
http://service.futuremark.com/compare?3dm05=826087
Settings;
nTune info tab;
Hypertransport Link - 1252.563 MHz
Memory Bus - 501.025 DDR MHz
PCI express bus - 3000.000 MHz
PCI bus - 33.000 MHz
CPU multiplier - 13.0X
CPU speed 3256.664 MHz
HT - 5X
Clockgen;
1.550 V
PCI-E - 119.97 MHz
CPU - same
Multiplier - same
HTT - 250.51 MHz
Memory - 250.51 MHz
PCI - 33.34 MHz
RivaTuner (video);
GPU core - 453 MHz
Memory core - 1312 MHz
RAM;
2.5-3-3-7-2T
Don't get me wrong here guys, I just feel that I didn't get what I paid for on the XFX's. The overclocking on the core GPU isn't the best, and I feel it could have been better for the 1200 + US dollars I spent on them.
I still appreciate my system.
Mike
ddogg
1,864
361
Settings;
nTune info tab;
HT - 5X
Clockgen;
1.550 V
PCI-E - 119.97 MHz
CPU - same
Multiplier - same
HTT - 250.51 MHz
Memory - 250.51 MHz
PCI - 33.34 MHz
RivaTuner (video);
GPU core - 453 MHz
RAM;
2.5-3-3-7-2T
Mike
well are u happy now?? :D
Whizzz
16
Yeah, I just don't like the extent I had to go to get that Mark though. Call it what you will, I wanted to get over 11,000, but should have been able to without the chiller system.
I guess I can live with being 27th ORB on 3DMark 05.
Mike :)
ddogg
1,864
361
lol i would be happy if i was 50th. btw how are ur XFX 6800GTs?? many ppl have been complaining about them saying XFX sucks yada yada!!
edit: nice little sidewinder u got back there!! always wanted to get one....never felt the need though!
Whizzz
16
I got the Ultra's not GT's, and yes I'm one of those complaining about the crap GPU core frequency capabilities. I guess I'll buy 2 more Prometias and mod to cool the GPU's to get the full core MHz. lol
Thanks for the compliment on my system.
Whizzz :)
ssvegeta1010
2,192
Id be happy in the #10000 of 3DMark05 ORB. But not if I spent that much I guess. My whole system was about the price of his video cards.
Ronin
4,563
server.counter-strike.net
10475
And stock, too. Didn't have to buy a cooling system to do that. I'd say you got ripped. ;)
Seriously, though, there's a limit to what you can do with the available hardware, and unless you're using a LS, you won't get the scores these cards can really do.
housecat
Banned
Oct 20, 2004
1,426
While you are quite obviously looking for 'oooo, aahhhh's. I will help you out instead, because while you have the money you are lacking attention to detail.
I like the rig, I like the choices in hardware. But one thing.. with all that stuff you should really swap out that Asus board for the DFI.
I did, never looked back for a second.
I take it you are running 250FSB.. which means you are more than likely running 2T.. huge performance loss.
If you have an issue with such small performance levels.. that would definitely make more than just a small difference.
Try 245FSB and 1T. Bench again.
You call yourself an enthusiast. Now get an overclocking board worth its salt.
I have a few other suggestions that you might have or have not done to improve your 3dmark.. but I think you need to take that Asus out of that overclocking rig right now.
CheesePoofs
3,163
Mine too. I think they should have a benchmark that measures the price to performance ratio, and gives you a score based on that.
Whizzz
16
Whizzz :)
Because I wanted to be able to have two sticks at 1T 550 DDR for some higher benchmarks. All four in dual channel 2T still works great. I had Corsair Twinx c2 PL before this RAM 2 X 512 and it doesn't compare to the G.Skill I have now. This RAM rocks and I have no regrets buying it.
Mike :)
Whizzz
16
Bull on this remark, I don't need the 'oooo, and aahhhh's, you are sadly mistaken. I dont need to repeat my previous posts, what's up with this crap, I'm in the video section here right? I'm expressing my feelings about my video cards, right? So WTF is the problem, you're probably young enough to be my son, I have 5 kids, stop acting like one. Just because I have a good system doesn't make me a show off!!!
One thing I don't lack is attention to detail, I know computers, I'm no newbie at this.
I was seriously considering this.
I can't run 1T using four DIMMS on this board. I've got good benchmarks from 250, even at 512 MB's 1T it doesn't beat out the four at 1GIG and 2T. The problem mostly hangs on the cards.
You're right about that one, I will.
Soon!
Thanks, and please, back off with the I'm bragging crap, I'm to old for this.
Whizzz
Whizzz
16
At last, someone with the same feelings I have.
Whizzz :)
CheesePoofs
3,163
Whizzz :)
Mike :)
Running 2T on an A64 system gives you a significant performance hit. IIRC, running 2T @300mhz is slower than 1T @ 200mhz.
