Got a few things last week to make my system quieter, since it's being used as a HTPC, and it's in my bedroom.
Specs:
Antec P180
eVGA NF-41 SLI
Athlon 64 3000+ Venice
eVGA 7800GTX 256MB
1GB Corsair ValueSelect PC400
I installed a Scythe Ninja on the 3000+, and found that I can run it fanless with no problems 🙂. I have both the top and back 120mm fan's working, but reduced to about 700rpm each. The CPU idles at around 32, and load is around 45 (hot, but manageable). Case temps idle at 45, and go up to 52 under load.
The 7800GTX has a Accelero X1 on it, and it's idling at about 56 degrees. It's pretty much silent.
Temp's are on the high side, but the system is 100% stable. It's been on for the past two weeks recording shows through Media Center and it works perfectly. And it's completely inaudible, especially once I reduced the northbridge fan speed to 1500rpm. I bought a Zalman heatsink for it, but I couldn't get the damn eVGA heatsink off, so I gave up. Oh well, the fan is almost completely inaudible.
Specs:
Antec P180
eVGA NF-41 SLI
eVGA 7800GTX 256MB
