OK, this afternoon I came home and played UT, and after a little while it locked up. I rebooted...it prompts me at the Client for Microsoft Networks logon...then as soon as I log on, it blue screened. I rebooted. Again.
I rebooted to safe mode. It booted fine. I noticed my device manger was COMPLETELY F-CKED UP! There were 3 video cards, 2 monitors, seven or eight hard disks, three Motherboard resources, etc. etc. I thought it was strange...I wiped the ENUM key (device manager info) in HK_local_machine clean and rebooted. It booted fine. It added all my hardware...BSOD again when it rebooted. Hmmm...........
Being that I was long overdue for a reformat, I just did it. I reformatted. I installed Wni98, my drivers, installed the AGP minport version 4.71 and the AMD Bus Mastering drivers version 1.22 (I think). I know The Win98 drivers are more stable than the AMD drivers but I have a PCI Bridge that is being read as an Unknown Device, so I thought the AMD drivers would fix it. It blue screened.
But it gets weirder. If I go into the control panel and uninstall a random piece of software (I thought it was Office 2000 so I took that off), rebooted, it loaded fine. But I rebooted AGAIN and another BSOD. So I go into the control panel and remove the AMD Bus Mastering Drivers. It reboots, finds everything, then blue screens. I reboot to safe mode, go into the Device Manager, and notice that I have five disk drives being read. Let me explain how this works:
When I have the AMD Bus Mastering drivers installed, it reads:
Generic NEC Floppy Disk
Iomega Zip 100
Maxtor <insert model number here>
When I have only the Win98 IDE drivers installed, it reads:
Generic NEC floppy disk
Generic IDE Disk type 47 (the Maxtor)
Generic IDE disk type 80 (Zip drive)
I removed the Maxtor and Iomegas, since I no longer had the bus mastering drivers installed, and it booted fine. This is where I am now.
This problem is so frustrating because I cannot find what makes it not happen reliably. There is no pattern. Furthermore, it survived a reformat, which means that it is none of my application software because right now I have Eudora, AIM, IE installed, none of which load at Startup (where it would BSOD at).
It has to be a driver somewhere. But which one? I am going to reboot after i get this off to see if removing the bus mastering drivers, and the excess leftover hard drives, did the trick. However I am not too confident.
Has anyone seen this before? FYI, the exact message is:
"Fatal Exception 0E at 0028:52263030...."
The address is the same every time.
Please help me.
If I don't post a follow up to this in the next few minuts, it means that removing the excess drives failed to work and I gave up. I will check this message in the morning.
I am desperate.
Iomega Zip 100
Please help me.
I am desperate.
