I'm building with some parts I've collected, including an Epox 8KRAI mobo, XP2000+ cpu, 1gb kingston value ram, and a 160gb sata (western digital) and 80gb ide (wd also).
So when all that is powered on it just hangs in the bios startup screen, it shows the cpu running at 100 FSB, the ram at 166 FSB, and the sata HD isn't recognized. If I unplug the sata HD then the cpu is correct (133 FSB), I can go into bios and set the ram back to 133, and I can successfully load BartPe. I set a jumper to force 150gb/s on the sata and was able to get past bios screen (it listed the HD then) but it was back to the wrong FSB settings. The HD only shows up as 136gb in Bios, and windows can't see it to install to it.
I tried F6 and using the sata raid drivers but its not a raid board and didn't make a difference. So all I can think at this point is a bios flash, currently Epox won't let me download it even though I registered.:disgust: Any ideas?
