My Sony receiver says PROTECTOR?!?!?!
CtK
5,135
its the STR-DE625 model
and we just hooked up a NEW Mitsubishi WS55807 TV and now the receiver keeps on flashing PROTECTOR on it...what the hell is that
we have tried unplugging it and leaving it for a few mins, reseted the whole system and nothing it keeps on flashing that
anyone seen or have this problem b4??
Crimson
Banned
Oct 11, 1999
3,809
Yeah, it means something is shorting out on the unit.. double check all your wiring, speaker wires especially, make sure none of the wires are touching each other.. I've also had a unit do that when it was just going bad.. I had to replace it.. but check the wiring first.. thats the most likely cause.
crab
7,330
19
My Sony reciever flashes that... It was shorted, mine needs a few resistors replaced on the speaker outputs.
crab
7,330
19
Yes, but you aren't sure that's your problem, it's just my problem. Unplug everything from it (speakers, inputs, antenna, etc.) except power, and turn it on. If it still flashes that, you've got problems.
